to make you feel better, you will probably make more power with the same setup, using a standalone with a good tuner vs stock + piggybacks.
89jdm7m;1901462 said:yea you should always be able to make more power with a standalone... piggybacks might get you close. might. That's not a good word when you've got a lot of money put into it. I plan on just running a OE shortblock on VPC + AFC w/ a .67/.70 t4 and 550 or 560 cc inj. Just to see what'll happen. (head ported for street use) I'll also be having another 7m o-ringedfor some serious seriousness
this is true... mk3 brent put down 630+ whp on a tired 7m (breaking up badly) (gt40-88, VPC) if you only want 400 or so whp... there really is no need for standalone...Dan_Gyoba;1901505 said:Nobody is telling you that you don't need to be careful when playing with a lot of power, particularly not me, but I believe that at the power goals that you've specified, and with the stated mods, a stand-alone is not a requirement for you to get there.
89jdm7m;1901473 said:this is true... I guess we'll see I've got 3 spare blocks. I know the one in the 89 I'm about to scoop is bored .40 over... there'd be no way. It is a bit close for comfort there in that pic, but I can't really see it being an issue... even if the rings were touching.
IJ.;1901511 said:...people are talking about 400>500 rwhp being "easy" it's NOT if you want any sort of reliabilty/longevity...
Grandavi;1901604 said:Boost-wise though, I am wondering if the max 15 psi is an actual number for OEMs or if its a safety range. Ideally, I would like to do 2-3 21 PSI pulls a year... and the rest of time run at 14-15 psi. (which would still be far better than the stock run I am used to)
always good to hear from those with more experience... I've only seen one o-ringed 7m (disassembled, not in a car), never even heard anything about anyone doing it until now. I may have to put a hold on that project if it's such a bad Idea.IJ.;1901511 said:Of course there's an issue, the o-ring is providing a very high load on a small contact patch, if the rings are close together this load becomes shared across the 2 rings so you get uneven loading around the ring and failure.
A 7M has to be one of the least applicible engines to o-ring (ALL of my previous Turbo engines were o-ringed but when I got my 7M I didn't go ahead)
A correctly installed MHG and a good tune is capable.
