Just wondering if I understand this correctly and looking for clarity so if I discuss it, I dont come across as an idiot.
Just rebuilt my shortblock and had to do a lot of talking/searching/reading prior to ensure I dont do it twice. Now I think I may have misunderstood something and want to see if I understand it properly.
7MGTE engine with rebuilt shortblock using OEM bearing/rods/rings/pistons.
(ignore the head gasket.. its metal with ARP studs)
Mods - 550 injectors, Lexus AFM upgrade, AEM AFPR, AEM UEGO Wideband, 57 TRIM CT26 (DM), 3" turbo back exhaust, HKS EVC-S Boost controller.
(no upgrade to intercooler yet)
Now, I asked around and was told that I would not want to run this higher than 15 psi boost on OEM pistons (not talking HP here) because they aren't considered "safe" at that level. I want to run a bit higher, so I went with Wiseco pistons (which has its own little problem potentials but have nothing to do with this question).
Is this incorrect or can you run higher boost on OEM's safely?
I may have been told to limit my boost because I have no stand alone system so have limited control of what happens to the engine tune-wise...
Just dont want to repeat incorrect information...
