Someone was telling me the other day that he plugs the oil squirter holes because it doesn't do much for the engine other then rob oil volume that should be going to the bearings. I'm not sure I agree, but I'm not sure the squirters are completely necessary with good set of forged pistons. They are probably needed more with stock pistons. There are lots of very high performance engines that see extremely high cylinder temps but don't have oil squirters. Another thing I'm thinking is that the heat taken away from the pistons is heating the oil, so your oil temp would be lower without the squirters. I don't know which is worse.
