Chris: The AU GE cooler is a pressure bypass cooler that bolts to the block where the 2 bolt blank plate is.
[thumb]http://ij.supramania.com/ports2.jpg[/thumb]
MA70AEROTOP;1187708 said:cool. so you have done a NA T conversion aswell.....how do you find it? Iam making mine so i can run NA for the time being till I get a oil cooler kit...just cap off oil drain etc.... as installing the single turbo CT 26 wont be that hard....at this stage ill be getting my MA70 working then ill upgrade the GA70 to a 7MGTE also7MGE/GTE = LOVE
Also Ian whilst its NA is it best to run the 1GGTE oil filter adaptor with water cooling or just leave it the way it is till i can get a cooler?
IJ.;1187884 said:Chris: The AU GE cooler is a pressure bypass cooler that bolts to the block where the 2 bolt blank plate is.
cjsupra90;1188768 said:Hmmmm, interesting!!!!! I always wondered what that plate was for... I wonder why AU GE engines got coolers but the US GE engines didn't?????
IJ.;1188812 said:It was a hot climate extra Chris.
935motorsports;1189123 said:My 7mge is currently on 7mgte electronics, coil packs, etc, and NA.
