Again, it all comes down to preference. If I was building a Supra for just scooting around town, I'd use something more along the lines of the N/A's compression ratio for more low end grunt, both in and out of boost. You can easily pigtail the signal wires into two outputs to satisfy the ECU. It's a non issue. Drilling the block for two KSs is also a non issue, so either way works. Many people prefer N/A->T simply because they know the history of their N/A motor.
I, for example, looked for an N/A block on purpose because the motor is going in my 4x4 Pickup. I wanted more low end, off boost torque. I only plan on 300-350rwhp, which can easily be done, both safely and reliably.
