eraezer;1683819 said:I see a lot of comments about improving swirl...but swirl is not really wanted in this engine.
When it comes to spark ignited engines you want tumble due to a flamefront growing from the sparkplug and out to towards the cylinder walls. More swirl in an SI engine will give richer residual gases which in turn will result in high HC.
With an diesel engine on the other hand, you want as much swirl as possible. Don't think I need to expand on this since this is far from subject.
Humps between intake and exhaust valves are also there to help avoiding internal EGR due to overlap between intake and exhaust cams.
EDIT: Seth, nice CNC work you are doing to the head. Good luck and I will follow your progress.
I thought you just want turbulence, and swirl was how 2 valve heads generate turbulence (air/fuel swirling in a circle as seen from looking down at the top of the piston), and tumble was how 4 valve heads generate turbulence (air/fuel tumbling in a circle as seen from the side)?
