doing a engine rebuild and im gathering a parts list for what i need for safely holding 500-600hp. so far i have
arp main studs
arp rod bolts
clevite77 bearing set
eagle rod set
probe pistons .40 over
7m gasket set
arp flywheel bolts
i found all this on drift motion, my only problem now is the main caps. $589 is a little steep for the billet ones on suprastore, does anyone have any suggestions? are the stock caps ok to go with? is an upgrade really needed here? (id spend the $589 if it was a good idea, but if its better spent somewhere else id rather spend it somewhere else)
any info?
arp main studs
arp rod bolts
eagle rod set
7m gasket set
arp flywheel bolts
any info?
