7M hit 18psi with stock AFM and still very rich...
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
IHI-RHC7;1020601 said:
It should run lean with a lex and stock injectors...
Edited. I wasn't trying to be an ass. We already knew that it should be lean.
suprafanatic
1,607
Greenwood, IN
lol, nothing new found yet the radiator just sprung a leak on me.. i got some leak fixer stuff that you pour in the rad. see if that fixes it... anyway when im in 5th gear and i boost, it will build up to 18psi and it holds it for a while then it slowly drops to around 12-13. now in lower gears it will boost to like 15-16 then drop to around 10-11psi.. on the dyno however the guy running the car said it went up to 15 then droped to 7. that was in 3rd gear... and i 'v never seen it drop that low before,, i found that wierd. but at that 7 pounds it dyno'd 288hp and 321ft. lbs. which isn't to bad. whish it would have held at 15 :D.. also without the SAFC II my car would be very rich at 18psi. i have it tuned to around a 12 on the wideband
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Oh no..That radiator stop leak is not good stuff. Not very friendly to your entire cooling circuit, like the small coolant passages.
IHI-RHC7
"The Boss"
Oregon
yeah, bad stuff.
I'm had good luck with the block sealant though. You drain the entire system, flush ALL coolant out of the system, then mix this stuff in, let it cure for 24 hours, flush ALL the block sealant out, and then refill..
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
When decent replacement radiators are around a $100.00 why screw around with stop leak crap?! You made baby jesus cry. :nono:
_
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
_
LMAO!
:yelrotflm
Hell, for $200+, get an aluminum 2 row core radiator.
ArmandoP
313
Indianoplace
keep in ind that those guys didnt really know what they were doing and had practically zero load on the dyno. From what I hear, it was the equivalent of driving downhill on an 80 degree incline... hence why all the low numbers on the turbo cars.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Yeah, you better learn how to launch in between now and then, too. Everyone called you and that MkIV dyno queens
