7M-GTE Engine Response
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Another thing to think about is having a dry sump vs a wet sump, and the diameter of the flywheel/clutch.
Having a small racing 6" clutch and flywheel would rev much faster than stock....
I'd be curious to put on a lightweight front pulley with only a belt to the alternator, and take the clutch out (just the flywheel) and then start the motor and see if it was that snappy...
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
Ry - Thanks for the info. I did read the N/A ITB thread. What I was trying to state was that the FXX motor was in fact close to that rotary while being a piston engine.
Doward - You're full of knowledge. Come on, spill the beans already. What's the diference between the 60º and 65º?
MDC - Yesss, that should help plenty by keeping the crank free from excess oil splashing around the pan correct? Also, can you give me more info on this 6" clutch/flywheel combo? Can it handle my HP Goals?
Poodles - I've noticed better response from the 7M motor without the PS on...
I guess someone who's replacing their clutch can have this done?
buldozr
362
North Texas
rotary is a different beast, now for apples and apples, comparing a ferrari motor to a 7m..... their rod to stroke ratio is critical in a high revving motor, Dont think its JUST THE STROKE cause its not, it comes down the rod/stroke ratio, rb26 like to rev, b16 honda motors like to rev(actually they have the closest to perfect rod/stroke ratio, still not a honda fan though) The biggest reason I see is the fact that the actual speed of the piston is slower on these motors at certain critical points of the combustion process, if you research it a little more, someone can explain it alot better than me. Throttle responce would come from efficiency(lightweight, low friction materials, hi compression, etc...)
EDIT: just buy a lotus or an s2000 and call it done.
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
Rod ratio has huge implications on the dwell of piston at TDC as well as a method of changing piston speed based on RPM (read as shifting the powerband). look at the Ford 2.3 4cyls (that are used in SCCA) there are a number of different piston/rod kits that fool with exactly that (rod ratio) to help with building a motor that works in conjunction with head/cam/turbo/etc as a package.
MDCmotorsports
Indy 500
Unless you're willing to spend the big bucks, and you are or know a machinest.... like my uncle Gueedo says... "Fogg-tta bout it."
The indy cars and alot of speedway (nascar trucks when qualifying) use a small 6" diameter clutch with 3 or more plates.
I think it will handle your horsepower goals....
Supraholics
Apr 1, 2006
1,577
PA
www.supraholics.com
I'm willing to invest, but not on a race team level :biglaugh:
