Stock valve springs don't loose seat oe open pressure. I measured mine (180K+ miles) when I was putting in CompCam springs, was using a Rebic LC to increase revs. I checked seat and open pressures. I don't have the specs on hand but they were within 2 lbs from stock pressures. I really doubt you can kick out a shim with the stock cams.
Airflow through the head, or lack of it is what will make revving to 8K worthless. I have yet to see a 7M dyno that made power over 7k with any turbo. Straight 6 cranks do have greater harmonic vibrations. Unless it's a roadrace car held near redline for long periods of time I don't think it would be a problem. 8K would put more strain on the rods though.
