*7M Crank RPM Limit*
In case anyone's wondering what I mean by 6M and 7M Cranks the early 7M's used a crank that's marked 6M and didn't have Counterweights on all of the throws then in 89 they got the 7M crank that's fully Counterweighted.
Look at #2 and #5 throws!
Top 7M crank Bottom 6M
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
joel w. said:
im such a pussy, i havent even hit redline... but im 160,000 miles on the block..
still pulls hard at 6k,,
Hahaha Well i have. Here we go,
I was cruising at ~60mph with cruise control. I came to a light so i went to disengage the clutch, thinking the cruise control would cancel like it should.
Well my car has a auto->R154 swap and the lazy ass second owner thought it best to leave out the clutch switch. Yes, that is the thing that cancels cruise control when you push in the clutch... And i didnt have one.
Sooo, I push the clutch and slowly begin to slid down in my seat with the "oohhhh shhhiiiittt" felling as my tach takes off. For a second or two i was as confused as my car was thinking, "WTH is goin on!" So i frantically swing around in a blur looking to stop this. I dont remember exactly but im sure i engaged the clutch 1000 times after putting it in neutral hahaha. Then i thought for a 1/2 sec and flipped the CC stalk toward me. The people i was passing must have been like wtf is that damn person doing.
All in all, I think my engine barked at me about 5 times as it bounced back of the limiter. To bad i was too busy looking for a way to make it stop i didnt look to see how high the needle went. lol not safe, not fun, and almost dramatizing. I was somewhat in shock the rest of the way home. I did pull in to a near parking lot to make sure that it was ok.
Im starting to think my engine has had a past rebuild... I wish i knew.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Valvetrain has nothing to do with the reliability of the crank. The crank would fail at the same rpm no matter what springs you have up there. Melloyellow I believe runs his 7m up into the 8k range. High rpms under a load or in a quick rise then fall is much safer than "hanging rpm" Meaning that if you run your motor up to 8k rpm and hold it there harmonics will will set up and tear your crank apart. How you balance your rotating assemby and how you drive will be the factors in crank life.
suprarich
Guest
Nov 9, 2005
2,187
ohio
You are right about that Figgie, but before anyone out there tries to spin their stock 7m crank to 9500, lets let everyone know that Woon has an aftermarket steel crank from Titan and is balanced and built stronger than ours.
shaeff
Kurt is FTMFW x2!!!!
10
Around
PorterzSupra said:
I have full 3 inch from turbo and MANY other mods but running stock cams and turbo and mine hits HARD at 3-5 but it looses power high up there in the RPM band so I shift early like 5 1/2 - 6. If I wento 7,500 my car would slow down alot
just for reference sake, larger turbo's wont lose breath at upper rpm like ours do. :)
also, with properly built valve train, and balancing, i think it'll hold 8k like it's job. :)
-shaeff
indio84
nightrider
Nov 17, 2005
holland
wel what i want know is what is the highest someone here has rev his stock 7m engine and does it everytime without problem i think it can handle 7500rpm without problem and that what iwill set my rpm at what dou guys think
Run my new motor to 7200 no problems at all but it's not your average build.
I'll run it to 8000 but will take some time working up to it in small steps.
With the right supporting mods it's still pulling like a freight train at 7200 and I suspect will do the same at 8000.
figgie
Twin Cities, Minnesot-ah
you are going to make me push the 9k limit aren't you :p hehe
ROFLMAO if you do it and don't post a vid I'll come there and make you suffer! ;)
Mine sounds awesome at 7200 and very different to a JZ engine at the same RPM! (7m sounds wicked revving the JZ's sound like a sewing machine)
(NOT hanging shit on JZ's they just sound very different at high rpm)
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
So everyone says that the valvetrain needs to be upgraded before reving to 7500rpm. Has anyone actually tried and see how high the stock valvetrain will run before it spits a shim or floats?
Tubbie: I sort of doubt many will have explored the limits on stock gear as to get around the stock limiter generally requires a standalone and by that time you've installed good springs anyway.
The stock springs are quite light seat pressure and most motors have sacked out 50.000+ mile old springs that have even less pressure!
indio84
nightrider
Nov 17, 2005
holland
hmm wel i'm going to run microtech with my setup but IJ has a good point the stock springs are quite light pressure so maybe i would set mine at 7200rpm no more then that if it breaks it breaks we will c
Indio: It shouldn't "break" unless you have some big cams in there!
It'll just float the valves drop off in power and sound really bad till the rpm drops enough for the valvetrain to stabilise!
You can just about change out old stock springs using your fingers they're so soft!
