and a bunch of these responses are exactly why I don't stop by often.
the yellow highlighted line is the heater bypass. When coolant flow is blocked or reduced to the heater, coolant flows out of the motor, through the highlighted line, to the water outlet. When coolant is routed to the heater, it partially flows through the heater return line, back to the water pump (as the heater has now done the job of the radiator on this coolant stream)
