70's Celica liftback w/ 1JZ
shaeff
Kurt is FTMFW x2!!!!
11
Around
that's sweet! i just found out from my mom that she used to have a '79 toyota corolla! i told her i wanted to kill her for selling it! haha
i love what people are doing with these classics. :)
-shaeff
supra_ed said:
mk1 rearend? thats a solid axle......nice. should have gone ford 9 though
celica and MKI supra are the same, they stretched the front of the car to fit the inline six and also strengthened key components (like the rearend)
it's a bolt in affair...
fstlane88
Single time!!
South FL
Dropping a 1J into one of those is a bolt in deal...Really? Or using the MKI rear end is? How hard are those cars to find FS in decent shape. I've been itching to build a true race car, and that would be a perfect starting point, so light.
waht he said ^^
though it shouldn't be too hard considing the engine mounts probably aren't too far off the pre-89 mounts...
tranny mount I dunno...
fstlane88
Single time!!
South FL
Man I'd really like to know, since you can put a solid axle in the rear pretty easily, it'd make a perfect drag car.
supra_ed
415
ohio
im just sayin...a ford 9in in a turbo supra would be sweet. ive only seen it once....but the guy also had a built small block in there. it was a low 11sec 88 supra, without any kind of tune.
Sawbladz
1,727
Oshawa, ON, CA
I'm not convinced of that. There was a 7MGTE Mk1 in PA that put out plenty of power but it's main downfall was wheel hop that seemed to have no cure. That car has since been totaled so I don't think a solution was ever found.
supra_ed
415
ohio
solid axle, if done properly, would never experience wheel hop issues that irs have
fstlane88
Single time!!
South FL
I've been doing some looking around and found a 73 Celica w/ a narrowed Ford 9" out back, so that's doable. I'll have to wait for someone more knowledgeable about wheel-hop to chime in, but I don't think w/ a solid axle, a properly setup suspension, and GRIP it wouldn't be a problem.
supra_ed
415
ohio
no siiirrr it wouldnt. solid axle is the way to go as far as drag race setup. ford 9s are cheap, durable, and easy to find. although the supra rearends are pretty badass for an irs setup
wrong, wheel hop isn't an issue on our cars in all the time I've seen em drag and been driving one.
IRS has less unsprung weight, meaning it's easier for the suspension to control. Wheel hop is caused by the loading of the suspenion and having it spring back. On a leaf spring car it's a huge issue as the axle will load up and twist the spring.
a good 4 link will get rid of a lot of it, but it's not perfect.
Celica and MKI supras had solid axles stock, the MKI axle was beefed up because of the larger motor. After looking at the photos I have of MKI's, they don't appear to have a leaf spring setup.
I'd have to see what the design is, but my point was that IRS generally DON'T have wheel hop issues as the real cause if the pinion climbing it's way up the ring gear, while on an IRS it doesn't have this force.
