Im just wondering why there isnt any 7m to 700r4 kits. ive seen countless kits for a th400/350 but why not a 700R4?
tissimo said:the a340e i hear is pretty strong? i mean 9s out of it isn't too bad..
Those same gear drives go for about 1-2k$ at that rate it would be more cost effective to buy a tranny from SP.The 700r is a costly tranny to build. First gear is very weak in them. If you want overdrive theres a gear vendors over/under drive system. It gives you the same 4th gear ratio as the 700r but you have the ability to split geras so you have a 6speed auto that wil keep you in your power range longer.
89turbosupra said:It is weak in stock form. If you go to bowtieoverdrives.com they sell them to any output you want.
grand nationals go easily into the 10's on there 200r4. how much diffrent is the 200 then the 700?
