Below 60mph the car seems to vibrate ever so slightly (almost not noticeable) But once above 70mph or higher the vibration gets progressivly worse. This is all coming from the front end of the car I believe.
What could be causing this? I know its not a bent/unbalanced rim since I have ran 3 different sets of rims in the time of this problem and the current set being brand new. Most common worn out parts on the MK3 are lower ball joints which should probly be replaced anyways, but also what about control arm bushings? If someone with some exp. on this could chime in and help trouble shoot this problem I would greatly appriciate it.
Thanks guys,
Chris
Thanks guys,
Chris
