Do away with the AFM altogether with Maft. or even better MaftPro.
Or do away with all the piggybacks and go standalone. Megasquirt is the same price as a Maftpro, will do more and datalog. You can choose whatever rpm you want for a rev limiter too.
bigal0043 said:
yea there have been some people that have ran 440's with a lexus afm they are asking for problems..
This isn't true. If you have a wideband, which anyone adjusting there fuel should have then you can see your AFR. If it's kept under 16 psi with a Lex and 440's it won't even get into the 12's, ok maybe a 12.1. It's the people that don't have a wideband and crank it up, especially with a stock fuel pump. Same can happen with 550's if you max them out too.
With an FCD my duty cycle was around 95% just before the rev limiter, measured with an auto DVM. I was well past whatever fuel cut there would have been even with a Lex.
