Ma70.Ent said:Most people say you should follow a 1 hp/1 cc ratio....(just about)
crrider80 said:If thats the case than running a Lex AFM would be safe with the 440 injectors? That doesnt really make sense to me.
-Steve
Ma70.Ent said:Uh, I think the reason people get the Lexus AFM is to eliminate the fuel cut/raise the boost at which the fuel cut starts working.
cjsupra90 said:470 flywheel hp is right at about the safe max for 550's in a 6cyl. at 85% duty cycle.
A very easy equation that will get you very close is
inj. cc X # of inj's. / 7 = max safe hp @ 85% duty cycle
so 550X6/7=471.42hp
Remember, this tells you flywheel HP and is for assumed .50 BSFC (brake specific fuel consumption)
WeDgE said:That would mean the 550s are only good for 391whp (assuming 17% drivetrain loss)...
:momaru:foreverpsycotic said:...no 440x1.25=550... what calculator are you using???
