well, i encountered this slight problem this weekend, i had to read through a countless amount of posts on here and supraforums to finally get a clear answer to my question.
when you swap a 2jz into a mk3 with the r154(a/t , idk if they could encounter this) the tranny crossmember holes may not line up, as if too forward.
where the mount bolts up onto the tranny, there is another set of bolt holes. use these to back the crossmember back a lil.
moust people don't seem to encounter this, as i found only 2 threads pertaning to it.
http://www.supraforums.com/forum/sho...&highlight=BIC
in the pics you see that the extra set of bolt holes are drilled and tapped. this was not the case on my tranny. ihad the tranny sitting out of the car for a couple of weeks, and when i realized this, the tranny was in the car. tapping and drilling these holes at such an angle while underneath the car is bitch. so guys, check this before!!
also if the car was originally an auto, the tunnel hole for the shifter will need to be trimmed ever so lightly, towards the front. not a lot, about 1/2 inch.
