2JZGE MKIII with 7MGTE Wiring and Electronics
88supraTT
292
around the bend
it has a turbo, but i just need to figure intake and exhaust piping now
also thinking I should have bought some black wire instead of using yellow i had laying around. once the car runs I'll go through paint and make everything look like a factory engine.
I can see the light at the end of the tunnel :aigo: :aigo:
88supraTT
292
around the bend
when I get this all said and done. I will attempt at making a write up with as much infromation as possible. hopefully will be done in the next couple of weeks.:icon_bigg
88supraTT
292
around the bend
alternator is in 2jz location, ignition....still can't decide
edit: to do list
-ignition
-intercooler piping
-fuel rail modification
-exhast
-oil lines for turbo
there maybe little things left, but I think I'm about 75% done
88supraTT
292
around the bend
sao1 said:
Any updates 88supraTT?
will get pics this weekend
-fuel rail is done
-ignition is in the place i want it, just need to pick up some new plug wires and mount it.
-received the boost logic oil line kit and somethings of coarse aren't working
-have piping for intercooler
-the biggest problem is mounting a exhaust of some kind.
I can only work on this for a few hours a week because of work, school, and the car is at my parents house 45 min away.
really really want to get this done before winter.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
On the heater hoses..
Facing the engine bay:
-Left, rear of block.. hooked it to port on passenger side of firewall
-Top of head... used a 90* bend and hooked it to port on driver side of firewall
This may not be the best way, but it was the easiest and has worked great for ~9 months :)
88supraTT
292
around the bend
its so close, everything is about done
found a downpipe just sent a message to the guy about buying it...4"
Ordered the fitings I need to make the boost logic kit work.
finished hooking up the fuel rail
finished the intercooler piping
ignition, just need to make some ground wires
i think that about somes it up...there is snow on the ground and more supposed to come.
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
Sounds good to me. So it looks like the '92-'94 Camry throttle cable is the best fit? Found this in a 2j swap thread: http://www.supramania.com/forums/showpost.php?p=804745&postcount=27
dok33
Apr 16, 2005
934
Austin, TX
Thanks, I'll definitely hit you up when I get rolling. I was thinking a bike brake cable might work, I've got a few feet of it in my garage. What'd you use? (sorry for the thread hijack)
mobes
Supras are never 'done'
Bozeman, MT
I used a bike brake cable with the fittings off of my old 7M cable.
