2jz plug and play
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I think 935motorsports does it. I don't know if it was for 1jz or 2jz though. Where ever I saw it, it wasn't cheap. But, probably worth it though.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
7M= great engine, but can have a lot of problems.
1JZ= easier swap than 2jz and it a blast to drive. Can take a lot of abuse
2JZ= harder swap, but hey, IT'S A 2JZ!!! :biglaugh: I've heard its the new cool thing to do. 1jz is so last year ;)
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
Your right AF,1J's are pimp and good but im 2J All the way, even though im selling mines :(
RacerXJ220
Interdimensional
Abalama
Weird, I thought 2JZ's were just as easy to install as a 1JZ.
I wonder if Dr. Tweak can make a harness for a 2J-GE into my MKII.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
might as well go all out and go 2jz. they are just built better than the other two flat out. probaly the most OVER engineered engine i know of. and we all know how easy it is to bust out 500 hp on one. plus even at that power level you can still be on stock twins with awesome spool. btw i think it is 935 who can make a harness.
p5150
ASE and FAA A&P Certified
Central Idaho
Its kind of hard to put all of the wiring into one harness. Some of the wires go to the dash and others go to other sections.... And are you using a 7m ECU? 2j ECU? Standalone?
I assume that you will be using a 2j ECU. If so you need to follow this website: http://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
The hardest part of the wiring is getting started. The website is hard to make sense of until you get into the wiring and start looking at it.
So in summary, you might just be better off using a 2j harness with ECU and splicing some of the few wires to the MA70 body
RacerXJ220
Interdimensional
Abalama
suprastanger507mgte said:
I think the 2JZ and 1JZ swap is almost the same in terms of ease/difficulty.
No way. Are you sure? ;)
p5150 is right, the hardest part is actually getting started. I hate wiring. Blah!
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
Dr. Tweak can pretty much do anything wiring related. I think for $500, he could splice together whatever harnesses you want.
www.phoenixtuning.com is his website and shows a bit of his work.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
oh the 1jz and 2jz im sure they are the same to install minus the wiring...
then again it costs twice as much as the 1jz to install a 2jz...
tlo86
Jul 24, 2005
3,914
Colorado
with 2j you need pans and the mkiii's drivetrain with a mix of 1jz parts and then you need a way to get all of your gauges working :(
p5150
Central Idaho
You should check out my build thread and the links posted in the first page. Its really not difficult to get all of that stuff together.
2JZ NA->T baby.
tlo86
Jul 24, 2005
3,914
Colorado
2JZ NA->T baby.
you are right it really isnt that difficult but it is costy Lol i think its more cost effective to go n/a 2jz to turbo vs 2jzgte to mkiiii, especially if you are like me and want to go single right off the bat. and 2jzge's are as low as 200$ and the average 2jzgte is $2100. front clips a few hundred more
at least my spark plug cover looks bitchin'
i love the colors too i always wanted to paint my car green
