2jz na-t on 7m or 2jz electronics
j3r3my
240
mass
well i picked up my 2jz ge that im going with a na-t setup with.i had planned on going with the 7mgte electronics&map-ecu route but to my surprise the motor came with a 100% mint harness(its a 93 harness).so should i just use the 2jz harness and re wire up the map-ecu to that? or just go with the 7m to make life easier?
thanks again,jeremy
Aem cheap???
If your going to turbo it now i would use either 7m or 2jzgte ecu. Using a n/a ecu might be harder to tune or you will just be adding tons of fuel.
j3r3my
240
mass
yea i might as well just use the 7mgte electronics
---------- Post added at 12:27 AM ---------- Previous post was at 12:26 AM ----------
and the map-ecu was basicly 100$ and its new,i got it from a friend
erags1092
hey guys i got a 90 with 7mge and i have a 2jzge that is going in and i plan on going na-t. my question is since i have the 2jzge complete harness and ecu and the 7mge. but i was thinking about going with a megasquirt 3+msx board. wouldnt it be easier to just make a new harness for the megasquirt.
