2jz na-t megasquirt extra
darkspeed
138
Montgomery, AL
www.pbase.com
good to see someone MSnS a 2J; I love the progress I've made with it.
A local megasquirter is doing a 2j in his nissan 240. I'll get some pics up when he's done. He's the one responsible for getting my 6M running primo
good luck with your project
jzxseven
70
south city, nor cal
hottscennessey;943165 said:
should be 1&6, 2&5, 3&4.
so from that order, do i just match that according to the edis 6 module.
i.e.
pin 10 (coil a) = 1&6, pin 11 (coil b) = 2&5, pin 12 (coil c) = 3&4
edit:
also what is the idm(pin 2) on the edis module for?
nissota
70
Jamaica
i.e.
edit:
IDM -Tach signal to dash
The1
Too poor to be here..:(
May 24, 2007
228
Austin, TX
Hey Darkspeed...I must put you on my "hang out" list.lol. I was thinking about doing at NA-T swap. (That's actually the motor I needed help pulling in the thread I made in the regional forum). I asked hottscennessey about using a megasquirt system I saw on ebay. Matter of fact, I will hit you up on PM..
*you may continue regularly scheduled posting*
The1
May 24, 2007
228
Austin, TX
This may sound real dumb..lol..but could I buy the wiring harness to prewire my car to run megasquirt?? :dunno:
darkspeed
138
Montgomery, AL
www.pbase.com
DB37 with hood
This will break the bank. Go get some wire at Radio Shack, or better yet, Waytek. Have fun
EDIT: Waytek also has these nifty weatherpack connectors (like GM uses)
GraffixWB
AKron, oH
hey all. I have ms2 extra installed on my 2jzge. I'm having a bitch of a time getting it to pick up a crank signal. the new code is supposed to supprt the 24 tooth+360 marker wheel on the dizzy. anyone had any success with this????
