2JZ NA-T into MK3
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i stumbled in and wow it looks good. the coil location i s where i see most coils and it looks good too
jmcboost
Missouri
I looked at it again and tried to put the thinner metal gasket in between the plate and the WG. It just doesn't look right. The metal gasket is not allowing the protrusion on the plate to slip down into the WG cylinder like it needs to. Either the metal gasket doesn't go there or it is not the correct one. I'll put up a pic of the gasket on top of the plate.
hottscennessey;981954 said:
You're right. The plate's protrusion faces the cylinder of the wastegate, with the thin gasket between the wastegate and the plate.
The thicker gasket goes between the manifold and the plate.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
hmm interesting, my only other suggestion would be running without the thin metal gasket.
I'm running without one and I'm having no issues on the same wastegate.
jmcboost
Missouri
I think that is what I am going to do. When I put the plate on to the WG it looks like it lays really flat on it. I dont think it will leak when I wrench it down.
jmcboost
Missouri
Well, not really. I have my old one which is 2.5 back to a cheep muffler. I do have a 3" DP and 3" test pipe. After that is all installed, I will probably make one myself. Why, you got one for me??:icon_bigg
antman
632
TN
Haha. Yeah I'll get it off my 2jSR5. It's in the mail.:)
Is the turbo your getting vband or bolt flange? Is the muffler 3''? If so, I'd throw it on. See if you like it. You have a welder at your house??
jmcboost
Missouri
Turbo will be 3" Vband. The muffler is 2.5" i believe. I can get ahold of a welder but have a friend that will probably do a better job then I ever would.
jmcboost
Missouri
No interesting pics. I am painting the engine bay in two weeks. and then I will start installing everything. I still need a turbo, injectors, and a few misc. parts. I'll snap some pics once the engine bay is painted.
jmcboost
Missouri
Here is the painted engine bay. Hope I can figure out where all of the stuff goes back on.
antman
632
TN
Looks nice. Now don't scratch that baby putting the engine back in.
Got any of your other parts yet?
jmcboost
Missouri
Yeah, now I know why not too many paint the engine bay. I already have scratches and chips in it. :3d_frown: . So give it a few months and it will look back to the way it was.
dok33;1008221 said:
Nice!! I'm going for the scratched up sleeper engine bay look :biglaugh:
jmcboost
Missouri
Here are some pics of the DM power steering line so I can use the 2J pump on the 7M rack. Also a pic of the oil adaptor line from DM. Does the power steeirng line look right? I am pretty sure it is.
jmcboost
Missouri
OK, I am trying to get the power steering cooler to go on the opposite side of where it was before. Here are a couple pics. The only thing I can think on is I may have some trouble with mounting the IC. Other then that, I hope it works this way. What do you guys think?
jmcboost
Missouri
Here is the other project right now. I need to figure out the AFPR routing. I think I have the lines right, but not for sure. So my 1st question is in the pic of the stock fuel feed and return lines, is line 1 the feed and line 2 the return? Also, does the screw on the back of the AFPR gauge need to come off? Any help would be great!!!
