2JZ Manifold Fitting to 7m Lets see.
Status
Not open for further replies.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
MK3Brent;1136138 said:
I hope you don't think I'm making negative comments, as I'm just pointing out the obvious. (At least how I see it.)
What exactly did you plan to do with this upper manifold?
I was not trying to say " you " yourself were putting out negative comments, i am saying any constructive criticism is welcomed. I always liek to hear the bad things or complications that may occur with this project.
I would like to weld the lower intake manifold to this, I will have to do cutting, but the stock lower runner is aluminum, and this is.. a different metal, steal so I may have to start from the ground up with this.. We'll see.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I see.
I didn't look closely or read details about the upper manifold you bought, is it steel?
If so, that's just another monkey wrench... You're going to need to make the transition from the lowers to this one with 6 different angled flattened pipes to re align them since the lower runners are not circular.
That's just one way.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Yeah, it's going to be hell if it is made out of steal or some sort o f metal that the lower runner will not work with! But hell I like to make things hard for myself as you can see this far, I have so many parts for this car I need to start putting things together.
NJBoostin
78
New Jersey
There was a write up on this same swap somewhere i'm almost positive i have it save on my computer ill take a look if i still have it. but anyway sounds like a great project keep us updated.
Flateric
946
Calgary, Alberta, Canada
I actually did exactly what you are thinking of here.
I got the lower runners for both the 2j and the 7m, alot of cutting and aluminium welding but you essentially end up with a "adapter" runner of sorts that allows you to bolt any 2j intake up to your 7m head.
I still have that runner here somewhere I think, not using it since I decided to do a 2j swap instead.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Yeah, I know there is a lot of work ahead here. It really is good though people have tried this though. It will be a fun little thing to start hope it comes in on Friday at the latest.
figgie
Twin Cities, Minnesot-ah
steel?
How exactly are you going to weld that to the stock ALUMINUM lower running? What type of welder do you have access to?
And lastly, how long do you think it will take to weld that up CORRECTLY? Regardless of what most everyone here things, TIME IS MONEY.
figgie
adampecush;1136392 said:
but money is not time....you think it would work both ways, but it doesn't!
actually it is. Only time it is not is when your number is up as no amount of money will get you out of that.
Now as for money is time. Sure it is. That when you pay someone else and they do the work for you while you take care of whatever it is that you need ;)
Money just got YOU time for x. ;)
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Ahh, I will say it makes everything a lot easier.. though it;s not a easy task anyhow.. it will be nice, I have three 7m lower runners so I can experiment ^^.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
IJ.;1136705 said:
Round to Oval isn't an easy transition then there's the pipe spacing.
Trust me it's a HUGE job ;)
Oh I trust you, but I think it's feasible, and it will be a lot of fun.. and disappointment too, I just want to try something new that's all. I think i would take ore pride in the car, if I had a lot of custom things I made.
Oh BTW: Those Defi Gauges I got I wiring them up today :) 110% perfect and still work correctly :D
I am very excited now. Senders don't even look like they were ever used.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
IJ.;1136656 said:
Looks different to the pics the OP posted Scott ;)
(happy I'm wrong though it makes life a bit easier for him,not much though it's still a massive job)
Yea it does.. and chances are the flange is warped. :nono:
Status
