2jz-gte vvti in mk3
valhalla944
17
west phoenix
i plan on using the stock ecu until i have some coin put aside for an AEM... but i have sum other things i have to do first... like fix the trans in my jeep haha.. gotta love setbacks, they always happen at the most inopportune times..
valhalla944
17
west phoenix
so i have a quick question... im under the impression that you splice the 2j engine harness into the 7m bodt harness so you can have your gauge readouts and other body controls right????
Mr Bojangles
268
Madison, WI
I have a vvti 2J and I will not be running vvti because the cams are too fucking expensive. Plus I'm running 264's for this summer only and then going bigger with a built engine and higher compression. At that point the bigger cams will offset the benefits of the vvti anyway.
destrux
1,183
10
PA
If you don't mind losing a ton of low end power to gain that top end power. The whole point of VVTi is so that the car can have a ton of low end torque AND have good top end power. It also helps fuel economy quite a bit. If you are going to build a high RPM motor and you don't care if it's gutless below 4000RPM, you're better off using a non-VVTi motor since they're less expensive.
Mr Bojangles
268
Madison, WI
Correct. It allows for 30 degrees of timing change and does give you decent overlap of the intake and exhaust. I'm running a 6266 on a .68 housing, stock compression and 264's with E85 so I should get full spool early which will help negate some of the lost low end. If you have adjustable cam gears you can degree them within the 30 degrees the vvti offers and keep the low end, but give up the upper overlap. For me the difference in keeping vvti is not worth the extra 700 dollars for HKS or Titan cams to run for just one summer. Then once big cams come into play, vvti is mostly negated.
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
also Chasebays.com does Brand new harness for the 1jz/2jz for any chassis. for 700 or 850 without a core. and has many options.
Mr Bojangles
268
Madison, WI
Not unless you're going to wire in all you're ignition, climate control and everything else that needs power like lights etc separately. It's about a lot more than making your gauge cluster work.
You really do need to do it the right way. Wiring is massively important.
IBoughtASupra
4,455
Queens, NY
valhalla944;1802164 said:
Aawesome... thanks for the tip.. what I wanna know is could I go with all mechanical gauges and bypass the wiring splice
No. Don't do this. It is not hard at all to do the wiring, pay for the harness and be done with it.
valhalla944
17
west phoenix
ya after i thought about it and asked around a bit i realized that ya it'd work, but i'd also have to wire the ignition, ligghts,, blahblah blah, and ya.. I found a company out here in phx, AZ that does wiring. www.proefi.com im probly gonna have them do it for me if i dont do it myself.
