2jz gte intake on 2jz ge head
sk6471
Quietly Lurking
May 28, 2005
91
Texas
How different are the intake ports for the 2jzge and 2jzgte? How hard would it be to modify a lower intake to fasten a turbo FFIM to an N/A head? Has anyone done this?
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
Boostage said:
riiiiiight because, new head,gasket, exhaust manifold, coil packs and electronics and harness= less $$..
I have researched the NA-T pretty heavily and if you can show me how to do a decent NA-T swap for less than the price of a 2jz-gte swap I'm all ears. It sounds cheaper, and seems cheaper, but ultimately it's about the same.
My list looks like this:
2jz-ge - $200
Head Gasket - $150
Oil Pan - $250
Manifold - $250
XS Power turbo - $350
Ebay wastegate - $200
Oil Line Kit - $200
Downpipe - $150
Intake - $100
Now here's where it gets interesting... It's all fun and games until you get to the fuel and tuning. Here's the part where you shout "7M Electronics!" But can you show me one successful NA-T running on the 7m electronics? No. Everyone talks about it, but nobody does it. Why? First of all, nobody wants to run AFM! Secondly, dropping $600 for a 7M piggy back on a 2jz is like doing Cindy Crawford with a blindfold on... it's just wrong, and what would be the point? :dunno:
Don't forget to factor in injectors, resistor packs, tuning, that funky intercooler piping, and you're about even with the 2jz-gte swap. God help you if you want a FFIM and/or if you go standalone, (like everyone does) because that makes the 2jz-gte is much cheaper, and a lot better looking. :naughty:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
uhh, the point of a 2jz na-t is horsepower for the money. aristo twins will be able to you to maybe 400, whereas the turbo on the 2jz na-t will be able to get you alot more. why buy a motorset for 2k and dump another 1-2k into the turbo setup for the same price. if you are staying stock twins, than yeah the 2jz-gte might be a better option, but if you are going for more power, than i would go 2jz na-t.
and to your 7m electronics, isnt scott running a 7m harness and electronics with a stinger standalone?
oh, and if you have checked the USDM 2jz-gtes, dont they also have an afm??????
OneJoeZee
Retired Post Whore
aboard the Argama
2jz-ge - $200
Head Gasket - $150
Oil Pan - $250
Manifold - $250
Oil Line Kit - $200
Downpipe - $150
Intake - $100
An NA-T swap may be similar in price to a GTE swap but what you're forgetting to mention is that when you finish an NA-T swap, you're already single turbo ready to make good power. Finish a GTE swap and you're still on stock twins then have to dump more money into it to upgrade from twins.
Those NA-T FFIM manifolds are not for everybody. Plenty people are doing just fine with the stock GE manifold.
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
Has anyone done this in a MKIII without a standalone or without a FFIM? If so, link me. That’s what kept me from doing it. The damned Boost Logic IC piping kit is $1200! Mine is all set up for FFIM from the 1jz, and I don’t want some crazy piping looking like homegirl from down under with the yellow car. You know who I am talking about.
Do we know anyone running 2jzge-t that doesn’t have a standalone? I know of Rafael (GeneStarWind or whatever) running just straight 2jzge and he’s pig rich.
So many questions…
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
dude, its the same deal as 7m-gte piping, dont sweat it. you could run a map ecu or vpc-afc combo if the look of an afm bugs you that much.
OneJoeZee
Retired Post Whore
aboard the Argama
So many questions…
Whether or not anyone with an MK3 has used the stock manifold is irrelevant. You don't have to use an FFIM. The piping is very similar to a 7M and nobody said you had to pay BL 1200 for a piping kit. Get it made elsewhere for cheaper.
A standalone would be best choice for any swap, anyway. You say it like it's a negative of the process.
gixxer750
2jzget comingsoon!
Mississippi
So.... Could I in theory run a 2jz-ge with the AEM EMS I already have for a 7m-gte?
Also... I could fab my own FFIM...not a problem.
Looks like all I would really need is a header(does SSAC make those for a 2jz-ge), a 1jz bellhousing, and an engine.....
I already have a koyo rad, big single, v-band downpipe(custom made, can be modded if need be), braided fuel line with AN fittings(could be adapted), AFPR, and all the other stuff that would interchange. This is most interesting. I think I will be going to the salvage yard to see what I can see...
Jaguar
Permanent Ban
Apr 4, 2005
489
SoCal
www.supramania.com
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
yep. if you use the 7m harness, you can use everything associated with it.
SD2JZA70
HardTunedMotorsports
San Marcos, CA
Quoted for the truth!
It is cheaper to go NA-T 2JZ because money saved in the initial engine cost is put towards performance parts that you would ultimately buy for the GTE. Standalone is the only way to go when building a high horsepower street car and would be needed for either engine when making big power.
I build IC pipe kits for less than half of that price and thats aluminum pipes tig welded,bead rolled with all clamps and couplers. Here is the 2JZGE manifold that I make. pricing is competitive with the other manifolds out there.
