Update
A little update:
-Relocated the heater valve to the trash
-Test fitted the Bomex bumper, then had to modify it, since the inside of it was hitting the intercooler. I'm still debating on how to mount it. Probably DZUS fasteners.
-Working on replacing the headgasket at the moment, since we pulled the intake manifold and found coolant sitting in the intake runners...plus, the car was missing at like 8lbs of boost (with afr's in the 12-13:1 range), so we're assuming that this is the cause of it.
-Adam (Supranforever) pulled the head for me (since I'm really pressed for time at the moment), bead-blasted the water outlet, polished the fuel rail, installed 650cc injectors, a q45 fuel pump, and afpr (holley 1:1 boost referenced) and is now waiting for a sunny day to replace the HKS headgasket for a stocker for the time being.
-upon removal of the head, he found that the people who installed the hg (prior to my owning the vehicle) didn't remove the rivets in the headgasket, and it didn't look like they'd even bothered to clean the block. I highly doubt they shaved the head, either.
For the moment, the 2jz has been put on the back burner while I'm away at school. I'm just hoping that the 100k mile 7m will hold up for a bit longer.
A few photos:
if you're horrified by sawzalls cutting into expensive front bumpers, you may want to look away now...
I promise you, that hurt me more than it did you.
and...
A neat turbo photo:
Next is a custom-designed ffim (using 4.25" tubing), new tires (hence the mismatched wheels), and hopefully some paint on the bumper/hood.
