Unfortunately I didn't do the fab work, I pretty much bought it done. I bought them from Ken, that's his SN on here, and he had bought the kit from someone else. I want to say RGGUY, but I can't remember exactly it's been so long.
But....Like I already mentioned you will need two front turbos, and on the rear turbo it looks as though the wastegate arm was cut and re-welded to position correctly. The reasoning behind the two fronts, I'm assuming is that they both have WG's so you can run them in a true twin setup with each turbo seperate of each other, on separate manifolds. Also, like already mentioned the Y-pipe will have to be completely custom, but depending on how you make the Y-pipe you may or may not be able to use a readily available DP for the A70 chassis. When I pull the twins off I'm wanting to put them on another 1JZ swap I'm wanting to do in a Cressida, and will be having a shop make me a new Y-pipe, that not only fits better but will work with available DP's.
As far as other parts needed, you will need all of the 2JZ intake piping for the turbos, and it was originally thought that you couldn't get 12b's to work with stock 1JZ IC piping, but I ran them with stock IC piping and the stock IC for almost a month with no problems. Umm, for a BOV for the time being I'm using a stock 7M, yeah I know LOL, but it works. You could also use a stock 2JZ one. I'm soon going to be adding a Tial to the equation, but will keep the stocker in place just cause, until I go single. I originally bought a 2JZ heatshield thinking I couldn't get the 1JZ one to fit, but it actually does, which is very cool, and throws people off just that much more.
You will have to beat the firewall in to install them like has been mentioned when doing the 2JZ swap. It's cake though, I used a torch to soften the metal and then used a 5lb. hammer to make it happen.
Some pics...
The setup apart...
You guys have anymore questions feel free to ask, I'll do my best to answer. Also if anything in my above post doesn't make sense blame the fact that I have tomorrow off of work and may be slightly inebriated. :beer:
