Zerocool;1054062 said:
Good stuff thank you youp! How much different are the USDM turbos compaired the JDM counterpart? What kind of work are you looking at getting two front usdm turbos on a 1jz other then making a bigger Y-pipe?
its like FSLANE88 said, if you can make the 4 bolt patern of the turbo to match the three bolt patern on the manifold, youre there!
and because the rear turbo is more to the back of the engine you'll need to bang-up the firewall for about 1 inch.
if you got the parts its almost a direct fit! you'll need to make a costum y-pipe and DP, costumize the IC piping from the turbo's.
the turbo oilline and coolant is with a little bending ready to fit, but i've done this on a 2JZ bottom-end and thats about 1.25 inch higher then a 1 JZ. dont know with a 1JZ.
i will make some pics soon, the pics from the built are gone...::shrug::
