2jz and 1jz ecu
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
are these 2 ecu's the same? will they work for the supra??
---------- Post added at 12:16 PM ---------- Previous post was at 12:15 PM ----------
i mean will the 2jz turbo ecu work with the jza70??? and if so..where can i get a jumper harness????
mobes
Supras are never 'done'
Bozeman, MT
To answer the first question, no they are not the same. You could run a 1JZ-GTE on a JDM 2JZ-GTE ECU since the sensors are the same, but the tune will be off. USDM 2JZ-GTE uses MAF instead of MAP so that is a no-go unless you want to add a MAF and the wiring.
Either way the ECUs and ECU connectors are entirely different between 1JZ and 2JZ.
Possible? Yes. Advisable? Probably not for a stock 2JZ-GTE ECU. I'm running a 2JZ-GTE AEM on my 1JZ-GTE, but a standalone is a whole different ball of wax.
