grifter679;1472549 said:Looking good, But personally a better job could be achieved by removing the fenders, I went back and redid some paint work because with fenders on, you will get a hardline between the chassis and the fenders, if the fenders flex, you will get crack where the mating surface is. pulling the fenders will also get you good acces to the front clip "frame" which i also painted, and also, pulling the fenders will let you get all of the old dirt and grime out. When your painting this stuff can and will get blown out and up and will settle in the paint. I also learned from this in a hard way when I painted the car, its a pain in the ass to wetsand nibs from base coat
sweetlikechutny;1472117 said:subscribed, you are making great progress!
taysmehu;1472525 said:Sweet :naughty:
grifter679;1472549 said:Looking good, But personally a better job could be achieved by removing the fenders, I went back and redid some paint work because with fenders on, you will get a hardline between the chassis and the fenders, if the fenders flex, you will get crack where the mating surface is. pulling the fenders will also get you good acces to the front clip "frame" which i also painted, and also, pulling the fenders will let you get all of the old dirt and grime out. When your painting this stuff can and will get blown out and up and will settle in the paint. I also learned from this in a hard way when I painted the car, its a pain in the ass to wetsand nibs from base coat,
When I redo my engine bay (when ever my tranny goes out) Im going to pull the motor, subframe, get everything steam cleaned, I will shave holes, just make it look tits.
But it looks like your doing a good job and your on the right path. also you find that you can hide tons of wiring when you start getting rid of stuff and miving things to the inside of the fenders.
88mkIIIproject;1472580 said:+1..looks awesome, but would have definitely removed the fenders too..you went so far, and removing the fenders is barely any extra work at that point. but i'm sure the end result will be great!!
Looking good Dale!You know what? This will decimate all... after we put about fifteen grand or more under the hood. If we have to, overnight some parts from Japan.
Mr.PFloyd;1473028 said:i really should have painted my bay when i did my last swap... oh well.
You do some good head work!
IJ.;1473062 said:Looking good Dale!
