1ZZ-FE coils on 7MGTE
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
i finally did go with these coils using the megasquirt. they will not clear the stock linkage without a lot of modification. what i did was use parts of the linkage and cut and welded my own so the cables come up from under the throttle body. no more ugly linkage and pedal feels much much crisper. cruise control works too. ill post pics sometime of my setup. and i love these coils... so nice
Albert
May 13, 2009
1,710
Tempe, AZ
Steven and I did a linkage delete on Jason's 7m. All we did was make a bracket with a hole to bolt to the plenum and u-shaped slot to hold the throttle cable.
The cable ran down under and through the plenum between 5-6 cylinders, and we spun the throttle plate 180 degrees.
Full linkage delete, no welding, no replacing any part. I used a drill and dremel.
eraezer
851
9
Stockholm, Sweden
Albert, was there any conflict between a coil an the pressure pipe running over the valve covers? I'm guessing not, but I want this confirmed.
Do you still have those coil mounting plates that I saw in some thread?
Albert
May 13, 2009
1,710
Tempe, AZ
Im not sure, the 7M that got those coils were for a FFIM.
I can make those brackets tho.
eraezer
851
9
Stockholm, Sweden
Albert, could you pm Me the price of one set of coil plates?
3.0 GT, did you use the stock pipe routing over the valve covers?
EDIT: I edited the text above.
eraezer
851
9
Stockholm, Sweden
According through PM, 3.0 GT told that the coils fits under the pipe, but it's very close.
I have not seen any pics yet, but I took a chance and bought a set of coils plus 2 :)
Hey Albert, where's the PM with the price for the coil plates? :)
jdemara
285
North Delta
Sorry - I have to ask... I am looking for a set of 1ZZ coils for my 2JZ swap... anybody in this thread have any sources for buying them?
Albert
May 13, 2009
1,710
Tempe, AZ
The nut that goes into the head that has a tapped hole in it, we replaced the others with those, and mounted it that way
