88mk3supra;1833513 said:wow car sounds great! did you go v160 yet? nice 1.5jz 300 too![]()
Rupinder;1834336 said:http://www.youtube.com/watch?v=OmvFvuTvF0Q
One of my friend's 1UZ TT conversion - just completed
enslaved87;1834518 said:Dare I ask...how long did this take to complete?Isn't this the one that you guys started working on like 3 or 4 years ago?
IBoughtASupra - Base timing is calibrated by locking the haltech to a timing value - doesn't really matter what it is could be 5, 10, 15, etc. - and using a timing light on #1 cylinder. Then you change the trigger values(tooth offset and trigger angle) until it is synced up.
IBoughtASupra;1834564 said:So you just keep cranking and changing the trigger angle and then see when it fires?
Lastly, and sorry to bug you, but where are the cam sensors on this motor?
IBoughtASupra;1834702 said:Found this video, it can help. Seems that at 10 degrees, 70 degrees work for the trigger angle.
http://www.youtube.com/watch?v=d31iRGvpVJI
IBoughtASupra;1835408 said:What's the plan for the ignition? MSD stuff or going with a smart coil setup?
Can't argue with those numbers at all and that motor, with it's internals, is probably barely breaking a sweat getting there. You tuned it yourself?
88mk3supra;1835453 said:god i fricken want one!!!! nice job man! car sounds so beasti bet it is nuts looking forward to seeing even more progress on this keep it up man
