Picked up this '87 turbo, from a co-worker for $1500. 9/10 body and interior. about 80k on a JDM engine, lots of newer parts, and a improperly installed MHG I'm re-doing right now.
I was browsing e-bay and picked up this generic turbo kit which spur-of-the-moment, I thought was a steal ($560) and would be a great start, now I'm wondering if I should use everything in it, however I think even tho they are generic components, they will still perform better than stock, and be a good bang for the buck to start with, untill I can afford to upgrade them.
I'm planning on getting the maft-pro, with the wideband and boost control kit to run everything. I'm friends with a exhaust shop that can build me a good 3" exhaust for it, and a connection at a toyota dealership to get some lexus 550 injectors.
engine has 155-160 compression, ran perfect, just was leaking exhaust into the coolant.
So I'd like some informed opinions on this turbo kit, if is all worth using, or if its totally useless and will cause nothing but problems (and why). I know theres a lot of fab work to do, which I'm fine with, I'm not new to building up cars, this is my first turbo build however, so I'm not familiar with turbo component specifics. my goal is just to build up a fun weekend car, and replace / upgrade components over time, but I'd like to start with what I have.
car:
pics and description of turbo kit:
* T84B T4 TURBOCHARGER
* 7MGTE T4 SUS TURBO MANIFOLD
* COMPLETE 40MM EXTERNAL WASTEGATE KIT W/FITTINGS
* COMPLETE TYPE S BOV KIT W/HARNESS
* UNIVERSAL ALLUMINUM INTERCOOLER 31X12X3 INCH "2.5 INLET AND OUTLET)
* UNIVERSAL INTERCOOLER PIPING X4 (FULL ALLUMINUM W/ 2.5 INCH DIA)
* SUS OIL FEED LINE KIT
* SUS OIL DRAIN LINE KIT
* FULL VACOUMME HOSES
* FULL FLANGES
* FULL FITTINGS
* FULL GASKETS
* FULL BOLTS
* TURBO INSTRUCTION / WASTEGATE INSTRUCTION
T84B T4 TURBO SPEC:
4" INLET DIAMETER
3"OUTLET V BAND
DRY BEARING
1/8 NPT OIL INLET
.84 A/R COMPRESSOR
1.15 A/R TURBINE
S TRIM ( OIL COOLED ONLY)
COMPRESSOR INDUCER: 2.324"
COMPRESSOR MAJOR: 3.00"
(USE V BAND FLANGE AND CLAMPS)NOT INCLUDED
manifold:
- T4 Turbo Flange
- 40MM external wastegate flange
- SUS304 stainless steel,
- Fully TIG welded
- Fully Ported and Polished
- Includes bolts and gaskets
I don't see why this generic stuff won't work, and build decient boost. I'm only planning on running about 15psi to start, and see how it goes (I know the turbo is huge, but for the price I'd like to start with all this.)
car:
* FULL FLANGES
* FULL FITTINGS
* FULL GASKETS
* FULL BOLTS
T84B T4 TURBO SPEC:
4" INLET DIAMETER
3"OUTLET V BAND
DRY BEARING
1/8 NPT OIL INLET
.84 A/R COMPRESSOR
1.15 A/R TURBINE
manifold:
- T4 Turbo Flange
- Fully TIG welded
