1st headgasket change--In process !!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
I love 'happy endings'...
I swear- every time I read a thread title that says ..."rebuild, but won't start"...I just wanna post CPS!, without even reading it, because it seems like it's the culprit 99% of the time.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
i'll make sure when my engine is done, i'll post the exact thread for you to put "cps" lol
MKIIISupraGuy
639
Lousy-ana
Well crap, my happiness was short-lived. Ran earlier today to get a haircut and to the store...car ran fine. Got it in a few minutes ago to go run a errend. Pulled out onto the road, and she wont go,,,kicks and bucks when I hit the gas, and I barely pressed the gas..like normal pressure for a basic acceleration.. Got codes 34 and 51, which I reset, no codes now, but still wont go without bucking hard and stalling when I depress the clutch....uggh.
Kevin
Apr 20, 2009
865
:( double check your i/c pipes etc for boost leak.. maybe something was loose and came off
check your tps if its in spec.
how you running stock boost?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
It's the CPS!!!!
Just kidding. Actually, it wouldn't hurt to try jiggling the wires coming out of the cps if they're a bit crispy with age, they sometimes loose contact.
But it does sound like an IC hose is completely loose or something.
MKIIISupraGuy
639
Lousy-ana
It was a loose IC hose. The one where it meets the hardpipe in the passenger front fender. I could actually feel the air escaping from it. Tightened it all up and she is fine now.
