1jz with different diffs
JustinGotA1j
532
Chilliwack
I'm looking for comments from all the guys who have done a 1jz swap and are using one of the american diffs and not the torsen. I am looking to swap in either a 3.73 gear set or a 3.91 gear set. I'm looking for all the pros and cons of each and any other information that anyone has to help me make a decision as to which diff will be better for my needs. My car is not going to be used for just track as it is my daily driver so I am ultimately looking for good cruising and also decent track performance. Thanks!
FIL
227
Thornlie
blog.highoctanephotos.com
agreed... i've got a factory jza70 (came with the 4.11 torsen) and have blown 2 of the torsens now, finally have a 3.73 mechanical LSD (claimed to be a TRD 2 way, but havent pulled it apart to check) and I've been very happy with it...
Quarter mile time is slightly better with it, and it also means you won't need to change to 4th just before you cross the finish line... :)
And 3.73 is great for highway cruising too... the 1JZ doesn't have a problem launching on it at all...
FIL
227
Thornlie
first one went during a motorkhana on the local drag strip, launched off the line and it just locked up.... split some of the internal gears and locked itself solid...
second one i dropped the clutch at about 50kmh and it went bang... was able to drive it for a little bit, but didn't make it all the way home before the parts inside it locked it up...
not sure exactly what killed them, i wasn't doing anything particularly special when either of them let go....
JustinGotA1j
532
Chilliwack
Thanks for the replies everyone. My diff hasn't siezed up yet but its whining pretty good when I cruise around. Sounds like the 3.73 is what's going to be best for me. Does the american diff swap right in or will I need anything special to make it work? Thanks
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
just out of curiosity, before your diff's blew, did they whine all the time, or just when there is no load on the diff?
because mine whines only when there is no load on it, ie not accelerating, or using compression to break. but as soon as i throw it in neutral, it whines quite alot.
thanks,
trevor
JustinGotA1j
532
Chilliwack
thanks,
trevor
These are the same symptoms I am having minus the whining in neutral. Granted I don't roll around in neutral much to really know if it whines then.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I honestly think the 3.73 is the best but not for BPU power, on the other hand I'm not a fan of the 4.3 craziness either. My 3.91 is what I consider the middle ground and the best, problem is theyre all old as hell.
supramk3man
414
kentucky
3.73 is best the car i have now is a 1jz it came with the 4.10 it was to low. You was out of first before you had time to think. Went to 3.91 it was fun but still alittle to low in first. So finaly tried a 3.73 and love it. Car gets around 22mpg city and 28-30 highway if you keep out of boost and not speeding.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
supramk3man;1053980 said:
Agreed shipping can be high, some time people seem to have trouble finding the 4.30 that is lsd.
well, if you know anyone with a 4.30 non lsd, ill have the carrier from mine for sale soon.
