So I just finished up a 1jz swap into my 86.5, swapped in the turbo tach from my front clip, hook everything up and and the tach doesn't work. I took the dash out to verify all my ground points with pictures I've found here, and I found one issue:
That is a picture I got from someone on here, I drew arrows to the two questionable areas. On the back of my cluster the green board has the provisions for those two screws, but no holes in the actual board. I'm assuming I need to cut into the board and put in two screws as they are grounding the tach or something?
I hope I was clear enough on that, if you need more clarification on anything, just let me know. Also, just to verify, I no longer need the white box that mounts on the back of the cluster?
Thanks in advance,
Jon
Thanks in advance,
Jon
