I'm getting 12v to the coil wires, Injecters are fine, I can smell the fuel on the spark plugs. So there seem to be fuel going in. I can hear the main relay turning on and off.
RPM signal, usually mean crankshaft or camshaft position doesn't it?
Anyone have a picture of how the timing mark on the crankshaft gear and
cam gear is suppose to be in what position?
When I was doing the timing belt on the 1jz before swapping it in. I was unable
to find the crank marking. So I took a stick and put it into cylinder 1 spark plug hole.
Crank the motor until the stick is at the highest point during the rotation. That would
be TDC. Other than that there was no marking on the oil pump to show where
it is suppose to be and no marking on the crank gear.
