1jz Swap Harness Help!
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
I'm in the midst of building a Plug-N-Play harness to go from the 1JZ engine harness to my Megasquirt. I will be routing the 1JZ harness through the OEM harness hole (LHD) and was wondering how close it reaches to the OEM ECU location? I need to know so I can go ahead and cut all of my wiring for the jumper harness.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Im going through the same thing,
Someone recomended routing the harness through the speedocable hole, Only thing is you must first "port out" the speedo hole for the harness to fit through.
tissimo
Stock is boring :(
Melbourne, FL
The ecu sits ~ 16" away from the firewall if thats what you're asking. Run ~ 20" of wiring from the firewall to the ecu to be sure I'd say.
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
Just the answer I was looking for. :)
Thanks tissimo.
