1jz Standalone Engine Management
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
have you guys heard of anti-lag? which standalone has that and which ones don't? its not two step, i've heard the stinger doesn't have two step. is this true?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Evilempire1.3JZ-GTE;1142418 said:
MOTEC > or = WOLF > AEM >haltec/autronic/megasquirt/TEC³ > HKS FCOV > Tec tom
Why's the HKS so low on your list? The F-con V-pro is an extremely full featured unit.
It's also one of the few that works with OBD2.
86_sports_1jz: If you set your timing super retarded on decel, most units will do anti-lag ;)
tissimo
Stock is boring :(
Melbourne, FL
aem ems has anti-lag.
hks is powerful, but its modified via dealer only. The end user has no control over the stuff. For some thats fine (They're going to get it tuned anyways and not touch it), for others they want to play with it.
figgie
Twin Cities, Minnesot-ah
My first question is why?
ALS makes the turbo a toss away part. The more aggresive the ALS (timing wise), the shorter the lifespan of the turbo. If you think it looks cool, it does! That is until the turbo dies and you have to buy another one which at that point, looking cool does not seem like to bright idea.
mr_240sx
10
Ontario
www.613driftwerks.com
hi guys,
instead of starting a new thread i figured id post in here to keep all the information in one thread for others searching just like me.
well really unsure what standalone to go with.
i own a jzx90 Mark II with 1JZ GTE.
mods that i will have for standalone are as follows:
550 injectors
T4 60-1 .57 ar
FMIC
Walbro 255lph pump
im hoping to get a tad over 400rwhp. anyways i have no clue when it comes to standalones. Heard lots and lots of good things from Power FC but for JZX90 they seem next to impossible to find and the ones you find are $$$.
i talked to Aaron at driftmotion and he mentioned the stinger. anyways i thought wow $900 pretty good. well turns out its nor really $900 as i need a $2XX harness. also unsure if ill need a boost controller or if the stinger controls boost as well.
AEM EMS seems overkill for what i need.
basically its a drift car that is also driven on the street. will be running 94 octane fuel. basically looking for a simple standalone that is reliable and easy to tune by a professional tuner. i like the idea of the Power FC because of the commander and how it acts like 10 gauges in 1 kind of deal. i hate having gauges all over the car.
basically i guess im stuck between Power FC and EMS Stinger. what would you guys pick if they were same price?
also is there any other management units that seems to fit what i need/want that i dont know about?
1 last thing, it must allow me to keep AC.
Mats
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
mr_240sx;1180115 said:
hi guys,
550 injectors
T4 60-1 .57 ar
FMIC
Walbro 255lph pump
Mats
I also don't have a clue about stand alone, but, i have a 1jz from jzx100 with 6860 and it works great. You will need wideband and boost controller but thats just 2 gauges. so far i didn't have problems with my set up. Zeitronix makes a great unit for your gauge needs, one gauge and lots of inputs.
slideways2004
98
Houston
hi guys,
550 injectors
T4 60-1 .57 ar
FMIC
Walbro 255lph pump
Mats
i'm kind of in the same boat except for i don't want a/c and don't ahve the same car. lol
right now, my setup is going to be:(not installed yet)
mines ecu
safc2
550cc injectors(not yet purchased)
