On Thursday, I had some more brake lines made. Left a deposit and went to pick them up on Friday and brought two more brake lines with me as well. The lines were made to be a little longer than normal because I wanted to route them a little differently and have the show. Can't spend 450 dollars to make Teflon lines and not have the show. Also have some pictures of the back area of where they make the hoses.
Friday I installed all of the lines and then tried to install my big brake kit. I needed a 1/2 an inch more of clearance for my wheels to clear. They are two piece Volks and the tabs on the inside of the rim rubbed against the larger caliper. Now I have to get bigger rims to use the kit. So what I did was, since the lines I had made used -3AN fittings on the caliper end, I took the stock calipers, bought -3AN to 3/8NPT and tapped the caliper for it. Hooked up everything and bleed the brakes on Saturday and did that until clear new fluid came out each caliper.
I need some rims, shoot me some suggestions that would go nice on my car.
On Sunday, I spent the whole day installing my gauges and routing wires. Mounting the gauge pod and getting it to fit how I wanted was a little tough. I taped each set of wires and used the cruise control switch for my power source since that whole circuit will not be used as I deleted it. Then I put the wires behind the cluster and wrapped up the extra set of wires that are outputs to a standalone. Then I cleaned and reassembled my interior to how it should be and was done for the day. It took my from 10AM to 10PM to install my gauges and neaten the wires how I wanted them.
Here are some pictures....
Lines For The Master Cylinder.
Where They Make The Hoses.
Guy In The Blue Shirt Made The Hoses. The Fat guy Was Just Walking Around With His Fisherman Hat. LOL!
Bunch Of Hoses, Some Rated To Handle 5,500 PSI.
Lines Installed, The Feed For The Rear Brakes Was Tricky Since I Had To Avoid The Steering Column And Could Not Bend The Hose Too Much.
Harness For The Gauges Spread Out.
Harness Organized
Standalone Outputs Wrapped And Tucked.(Blue, Yellow And Orange)
How It Looks When I Was Finished.
