honestabe;1049211 said:FIL, we speak in thousandths of an inch here. Nobody sells a spark plug gapper in mm. Just thought I'd let you know. Remember, gap the NKK 6097's at .028 and don't forget to heat shrink your coil pack stems while you're there (5 minutes to heat shrink the coil packs).
Adam
I have a feeler gauge with mm which I use for gapping and I believe the tsrm also mentions in mm. :biglaugh:
Yeah always gap your plugs . check the coil packs as cracks in them can cause arcing. Also check your coil plugs itself. maybe brittle and broken and not making good contacts.
