IBoughtASupra;1770379 said:You should check your coils for the sputtering. When does it sputter? In boost? Idle?
Idle and it back fires in boost @ high rpms
Sent from my SGH-T959 using Tapatalk
IBoughtASupra;1770382 said:It is highly likely to be your coils. I have seen this issue many times. If you decide to pick up a set, I have some for sale. DO NOT PM ME unless you are sure it is the coils.
Have someone or another car to swap over a good set and see.
IBoughtASupra;1770397 said:You are using a narrowband. It is not good for tuning an engine.
IBoughtASupra;1770447 said:How much boost are you running? What are you tuning on?
soso714;1770504 said:I wish my freaking car was doing this oh my gosh I can't even do anything other than idle :'( I haven't even gotten the chance to hear it rev let alone turbo spooling open waste gate flutter tire spinning nasties!
Good luck hopefully u are at the end of this journey of a headache!
Radial;1770672 said:Great to hear you sorted out the FCD/MAP problem, and got the car running again.
But remember chris.... you have probably been cloging your sparkplugs bigtime with the fucked MAP/FCD-setup. (running rich as hell, black smoke)
Clean your plugs, or by new ones. Hotest tip you'll ever get.
Regarding o2:
it's a 3-wire o2.... two wires are for heating (same colours), and one is often white or blue...thats the signal wire.
You should clean the 02 with water, and dry it with a hairdryer or something similar.
A Narrowband o2 is working between 0,3 and 0,8 volts (signalwire to ground). when engine is running, it should be flexing up and down between 0,3 and 0,8v.
If it does so, it works. But you need a very quick responding Voltmeter, as it changes within half a second. If your o2 is stuck @ lets say...0,3v it's fucked. And your ECU will throw a code, as the voltage is not flexing anymore.
The ECU will also throw a code if the Heating-wires dont create a "circiut" for the current to heat the o2.
IBoughtASupra;1770719 said:Major boost leak?
