1jz -ati damper
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
Mine broke apart a few months ago, I went with the fluidampr. Its 1 piece, fit super easy, looks stock and is very nice. Got it from summit too. I got the 2jz-gte pulley and used the normal belt for the 1jz w/ air.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
mine has cracks on it (1jz) the 2jz one the whole belt assembly fell off... fucking dampers are shit (stock that is)
scottiedawg66
Bay Area Ca
Bump from the past. Are you all running the 2jz ati unit on a 1j? I am about to replace my damper. Want to make sure the 2j unit is the way to go.
Edit. Just got off the phone with ati. The 2jz unit is good for the 1jz as well.
My next question is what serpentine belt are you using? I only have the ps pump to run as i am eliminating hydro fan.
MNBmk3T
217
Burnaby, BC
I'm already on my 2nd crank pulley as well and I only swapped in my 1J in April 2012. I'm gonna invest in a Fluidampr unit hopefully before I go single.
f00g00
586
Kuwait
The ebay link had the gates belt number on it. Even with no hydro fan you still have the water pump so the belt would be the same for both setups but not OEM.
