Last night I checked the CPS again, It was definitely off. I pulled a plug to be able to make sure it was at TDC, and the timing marks lined up. The problem is i can't get it to start and idle on its own, to adjust the cps, so I had to have someone help me, It seemed like when I did adjust the tps, we got it to run really well over like 2000 rpm, well pretty well.
Still have a long ways to go. I should probably put at least the downpipe back on, fill it with coolant, and attach the belts and alternator. Will try to get another video up today.
The oil leak is solved so thats good!
