With the transmission and flywheel/clutch off I was able to mount the engine to the stand. With the head still mounted to the crane I slowly let it down, and it looked like the stand was sagging a big. I didn’t want to risk it so I left it on the crane supporting most of the weight of the engine.
I started by taking off the 3000 pipe. I took as many pictures as I could to make reassembly easier. Vac diagrams can be confusing and finding what goes where and how will help when it comes time to put this back together. After the 3000 pipe I took off the throttle body. That thing was incredibly dirty on the inside. I am going to spend as much time cleaning the components as I will taking it apart and rebuilding it. The back side of the butterfly valve were covered in thick black residue. It’s going to take a wirebrush to get it down to the bare metal again. Various hoses and tubes had to be disconnected to get it off. The throttle position sensor just disconnected easily. It took a few light taps with the persuader to knock the upper manifold loose, but the seal broke and off it came.
I guess I got a lot of cleaning to do
---------- Post added at 05:49 PM ---------- Previous post was at 05:47 PM ----------
Today was warm out. I worked in the garage without my jacket, it had to be around 55 degrees. I can't say that I mind it at all. I started taking off the exhaust side manifold. I started with the turbo. I know the bolts on this side can be very difficult to remove. Luckily I didn't have any trouble whatsoever with the turbo. In this picture the heatshield has been removed from the manifold and I began testing the 4 bolts holding the turbo on. They all broke free easily. Three came off using the ratchet, but there was one hidden that had to use a small wrench for. Annoying.
The underside of the turbo. You can see the oil return line bolted to the center housing rotating assembly. It looks like it would be some kind of flex material but I assure you it is hard as metal. This return line needs to be unbolted from the CHRA and the block.
Top view of the turbo. These are the water cooling lines. At first I thought I could just disconnect them and be OK, but once everything was off and I couldn't get the turbo off the studs I caved and removed the water line block as well. It came right off after that. Do the job right the first time and you save time.
Turbo is now off, you can see the water lines still attached to the pump and disconnected from the thermostat. I needed to get the turbo off before I could get to the second heat shield closest to the crank pulley. The oil return line is still hanging because I didn't remove it from the block. It is still bolted to what I assume is the oil pressure sending unit.
Side view of the manifold sans turbo. Oil and water lines visible, and a nice close up of some connector. The harness had to get removed too.
I was on a roll and just removed the manifold. If you look closely you can see the studs came out in a few places. I think 2-3 came out, and it looked like they still had the threads attached. It's going to be a pain in the ass to have those rethreaded. I will most likely have to get them in a larger size. Close up of the thermostat and throttle position sensor. I had just removed the bracket that covered up the thermostat. The wiring harness has also been removed in this picture.
Next were the coils. Four little screws hold it down, and they each go to a separate cylinder. When I pulled them out, they were covered in oil. Upon closer inspection the spark plugs were sitting in a river of oil. I have no idea how thick or where it was from. My guess is the cam cover gasket?
Cam cover off on the exhaust side. I didn't want to take the cam out because I had no way to keep these retainers organized. I think I can still remove the head with the cams in but I should do some more reading.
Front timing cover off. I need to get the crank pulley off next. My dad is going to bring home his impact wrench and I hope I can just pop that on and break the crank pulley off. Need to do some reading on that too.
By the end of this week I'd like to have the head off and maybe start looking at the internals of the block. At some point I need to wash this thing.
