14" or 16" Electric fan(s) on my car ?
Status
Not open for further replies.
YoNkErS87t
streetside mechanic
In the Garage
i know a few people running the ford contour fans with big hp and no problem.
I believe it is 95-96 v6 contour fans that they use and they fit up very nicely
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Chris, the guy that had clutch problems at the supra meet last weekend has those fans on his. He said he dyno'ed at 480 before the new turbo kit was installed. I'd say he had those fans on there then, so they're probably good for as much power as most of us will throw at them.
When I first seen them on his I mistook them for FAL fans.
ross1
188
va
supraman7mgte said:
i have a PWR,and it was one of the best investments i've made. it's been going good for at least 5 years.
WARNING: Do not run stock fan shroud with thicker radiator!!!
when i put my pwr and taco clutch in last summer i ran fine with the stock shroud, why do you need something thinner?
ross
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
I'm no familiar with the contour fan set up but just like any other fan set up u can keep your a/c......i would go with a 14" permacool fan rated at 2950cfm thats 450 more cfm than the dual flexalite setup.......and wire it up to a adjustable temp control switch and u should be right on the money good luck with the route u decide to go with....:icon_bigg
Status
