1/2NA/T hp numbers???????????
89supramk3
arlington tx
hey thanks guys keep the nuber comeing because your gonna see a killer 40.000mile 7mge kiss the 350hp mark with the 1/2na/t :naughty: crazy that you guys made this much horespower with small psi when i do the 1/2 na/t 11psi 350hp jic ss 3in' catback test pipe r154 3.73 rear end cuco lsd and all of the regular 1/2na/t toys
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
if NA-T is the route im going, its going to be on at least a 57 trim, and there is a good possibility of it being a or equivalent
89supramk3
arlington tx
a stock ct26 would max out at around 250hp but when ported does it push out to the 350-400hp:evil2: ............ thats bad ass but im looking for 350hp with a 40.000 mile motor with a replaced head gasket new oil pump and cam regrinds:naughty: my car is sick but shes down for the count due to a blown out auto tranny. soon turbo tranny
lifted
157
memphis
s383mmber1 said:
Would you mind telling me were you got this information, because it is very incorrect!
i would agree, i-ve seen numbers from na-t`s with the ct-26 making higher than 250. the ct-26 will max at about 14psi, how much hp you are making at 14psi depends on alot of things other than the turbo.
s383mmber1
3,614
Somers New York
Yup, Shaeff, here on the forums hit 300 HP on a 7mgte (lower compression) and just realy basic mods!
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
someone dynoed their NA-T with all stock turbo electronics and a stock ct-26, bic DDP and a 3 in exhaust, at stock boost he was around 240whp.
89supramk3
arlington tx
ok ok what should be the maximum alowment on the 7m-ge internals from what i know they can hold 500hp because, the internals are made out of the same material as the turbo 7m. But the 7m-ge has flat tops insted of dished out piston and piston oil squerters............. so what is the maximum alowment of the 7m-ge with 40.000miles as for internal wise:1zhelp:
turbodriz
mk3 onwer
Feb 25, 2006
471
newyork....N.c
I just wanted to make a very simple comment. That is what you get when you yeild a higher compression. Faster spooling time, more torque, and if your not careful more detonation. We run 10:1 flattops on turbo hondas. They tend to run very warm in the summer on boost. But the spooliage ,hp and torque is there with less boost. I wanted to run 9:5:1 in my gte but the more experince guys told me it would be a bad idea on the gte motor. So I'll do something like that on my 1j when it's time to build.
NA86.5
NA-T Complete Yo
Jan 20, 2006
459
Alice Tx
Anyone with a answer for this question and what would be a safe pso setting it would help me out too thanks
