Installed EMU on 89 w/7mGTE and lexus AFM, but I didn't anticipate a few setup choices, can't find info, etc., and I'm wondering if anyone is still on here that has used this system.
My question: is it compatible with the Karmen Vortex or do you have to convert to MAP sensor to use EMU?
the software menu for the EMU setup program does not give a choice for toyota karmen vortex, only mitsubishi, so is any setting appropriate for my engine? Any other suggestions for software setup parameters much appreciated.
I searched a lot before installing, got the ignition signal mod installed, and saw a lot of info on jumper settings to give me things to play with.
Right now it cranks but just won't fire up, but starts fine when I bypass the EMU by reconnecting the engine harness wires that were cut during the installation.
Thanks!
Thanks!
