my mods SAFC2, 640cc injectors, MBC 14psi, walbo, adj-FPR, AEM wideband, and forged internals .20 over.
i recently got it back together and was wandering if there is some settings on the SAFC2 to get it to run not so lean? it will be good when i first start the car up at like 11.3-11.6 AFR. then i will drive it for about 5mins and it will spike up to off the charts then to 15.5-15.9 and i will let it sit and idle at that AFR and try to adjust the FPR and nothing happens and this is driving it at under 2100rpms the whole time before i try to adjust the FPR.
it will stay at good AFR in the real low rpm range in 1,2, and 3 gears which 3 was the highest gear i went to and sometimes it will spike up to 15-17's.
what could i do or try to get it to safe AFR's as i break the motor in?
any and all help is very welcomed
trev
trev
